Thank you for posting details information. Glad you are enjoying the car and that everything went smoothly with the trip.
Did you or has anyone else used the navigation map to determine ice or electric use?
Is the car smart enough to do that on a long road trip?
Are you talking about the smart energy distribution? It works pretty well, even on longer trips. In Hybrid mode with a destination set in Google Maps, it will always try to get you to your final destination with 0 electric miles left. On longer trips, this basically means all highway will be gas, and all deceleration, coasting, downhill, stop/go, and city will be electric.Interesting question, also wondering.
For the whole kit with case and all is about $575. Cheaper options available without the case and tools, etc. I made a thread about mine with some pics if you're interested.bigger, heavier car would definitely ride smoother and more comfortable. How much did Modern Spare cost you?
I did this on the last 4 hours of the journey and about 30 miles of battery range left. It dropped to 0 battery miles within about a mile of my house and pulled my average MPG up by a few miles. What I’d not tried before was the hold battery function in hybrid. I use Pure as my default start mode and hitting hold switches you to Hybrid but as a mild hybrid only. So electric in stop and go with a smooth engine engagement at about 10 MPH or even higher if easy on the pedal making for a very quiet and relaxed drive. The engine shuts off on coasting/decelerating and all downhills and you wouldn’t even know it but for the power display gauge. It works so well that I’m going to start using this whenever I jump on the highway in Pure mode.In Hybrid mode with a destination set in Google Maps, it will always try to get you to your final destination with 0 electric miles left.
The best way I’ve found is to start with the final destination, “Hey google, navigate to…” then add all of the stops from last to first in the same way. They pop up on the map for confirmation and drop off (or can be manually deleted) as your trip progresses. I do this for general waypoints as well if I want to avoid certain cities, bridges, etc. and just delete them from my trip via the screen once I’m close to that location. For a round trip you can start with your current location and add stops or waypoints and these will be inserted in that same last-to-first order mentioned above.programming multiple stops and round trips could be a bit easier.
Pretty much what I did, thanks to your earlier post. It was a challenge to start at home and enter that first with the default telling me I have arrived. It just seems that a round trip should be an easy selection in Maps, unless I am not using it properly.The best way I’ve found is to start with the final destination, “Hey google, navigate to…” then add all of the stops from last to first in the same way. They pop up on the map for confirmation and drop off (or can be manually deleted) as your trip progresses. I do this for general waypoints as well if I want to avoid certain cities, bridges, etc. and just delete them from my trip via the screen once I’m close to that location. For a round trip you can start with your current location and add stops or waypoints and these will be inserted in that same last-to-first order mentioned above.
Yeah, it's pretty annoying. Really hoping a future update makes this easier like the mobile app. You should be able to add and rearrange stops easily by dragging/voice without having to start backwards chronologically. I have to drive half a block away from home before I add "Home" as a destination, and then whatever place I'm going to as a "Stop" before it.Pretty much what I did, thanks to your earlier post. It was a challenge to start at home and enter that first with the default telling me I have arrived. It just seems that a round trip should be an easy selection in Maps, unless I am not using it properly.
What I ended up doing was using a different house number on my street as the start and end point. That worked, but it’s obviously lacking. Thanks for you guidance, pun intendedYeah, it's pretty annoying. Really hoping a future update makes this easier like the mobile app. You should be able to add and rearrange stops easily by dragging/voice without having to start backwards chronologically. I have to drive half a block away from home before I add "Home" as a destination, and then whatever place I'm going to as a "Stop" before it.
