1 - 20 of 38 Posts
So I had some spare time the other day so I decided to do a how-to on installing a shift knob that you need to thread the shifter shaft for. My shift knob of choice was the TWM M1 Abrams Satin knob. I find it goes perfectly with the interior trim of the car and it matches the stock shifter shaft perfectly.
Installation time: approx 45 min
Tools you will need:
1. Vice grips
2. Tap and die kit with a 8x1.25 tap. Should be able to find this for under $50 at pretty much any hardware store if you don't already have one
3. 15mm open end wrench
5. 1 square of paper towel
4. A decent amount of elbow grease
STEP 1:
You're going to want to start I started off by removing the stock shift knob. Simply push down on the shift knob and turn counter-clockwise. I don't have a picture for this but to be honest, I don't think it's needed lol.
This is what you will be left with:
STEP 2:
Now you're going to want to get that pin out. For this we're going to use the Vice Grips. I used a set that had small flat teeth. Basically what you want to do is get a good grip on the big end and try to turn it to break it free. Then you'll simply need to be patient and pull outwards while rotating the pin until it comes loose. It takes some time and effort but the pin comes out intact this way, so if ever you want to go back to stock, you'll be able to.
Place the pin in a place where you'll find it if ever you need it again
. I put mine in the center console.
A few pics:
STEP 3:
Once the pin is out, it's time for the annoying part lol. First off you're going to want to punch a whole in your paper towel just large enough to fit the shifter shaft through. This will cover the rest of the interior from the metal bits that will fall when we will thread the shifter.
Should look something like this:
Now grab the 8x1.25 die and get warmed up because this is gonna take some effort lol. It will most likely take you 3-5min to get the die going so don't get frustrated. Also make sure your die is being used in the right direction (one side should be a bit wider to allow the threads to be started easier).
I didn't use any cutting oil because it was just making it harder to stay on the shifter. Keep double checking to make sure you're straight.
The result should be something that looks like this
STEP 4:
Now if you're installing a TWM Performance shifter, you're going to need to install the hardware. You should thread the die down until the aluminum insert is sitting flush and covering all of the threads.
Should look like this:
Once the height is right, use the 15mm wrench to tighten the aluminum insert just slightly. BTW, this is the method to have the shift knob sit as low as possible. If you would like to have the shift knob sit higher, TWM provides spacers with their shift knobs that you simply throw into the shift knob to give it that extra height. You have about 1-1.5inches of height adjustability depending on the shift knob model.
STEP 5:
Now simply screw on the shift knob. I tried a couple out and decided to go with the M1 Abrams in Satin finish but I took a picture of a couple of the others that I thought also looked good.
TWM Performance Satin Type R
TWM Performance Satin Big Type R (simply a big version of the type R)
TWM Performance Satin M1 Abrams
I hope you guys enjoyed the walk through. In the end from the time I drove the car into the garage to the time the last shift knob was screwed on, it took me 45min. Let me know if you have any questions. All comments are welcome
Modified by patrickd_21 at 10:11 AM 3-10-2010
Modified by patrickd_21 at 10:12 AM 3-10-2010
I'd love the stock shift knob too much to ever change it, but still, everyone loves to see DIY threads!
nice write up
Moderator
Re: My first mod to the V70R (patrickd_21)
I'm glad you like the new shifter.
....but I HATE the spaceball....deleting it was one of the first mods I did
Re: My first mod to the V70R (tomedkaz)
Quote, originally posted by tomedkaz »
I like my spaceball lol
Nice write up, I just did this MOD as well with the gunmetal Abrams. Did you buy all three of those? Hope your able to return the two you don't like! Is that a bass knob to the left of your shifter?
Re: My first mod to the V70R (FastR)
Quote, originally posted by FastR »
The knob to the left of the shifter is to activate my Ipod connection.
i don't think returning it will be a problem for him.
excellent write up, since my m1 abrams arrived monday, it's on the list for the weekend. you answered my only question, and that was how far down to thread that insert. http://********************/smile/emthup.gif
the m1 has nice heft to it, is well made, and the engraving on the curved surface looks great.
Re: My first mod to the V70R (atacamaR)
Quote, originally posted by atacamaR »
Good stuff
. Also cool to see that you went for the engraved option...I didn't even think about trying it to see how it would look so I'm excited to see your pics http://********************/smile/emthup.gif
Quote, originally posted by patrickd_21 »
Good stuff
yeah, i debated it whether to do it or not, not that i need the indicators, and... they are already on the spaceball. but figured it would look alright.
i'll be sure to post some pics.
the satin seems to pull the plastic parts of the spaceball together too, i always hated how it was different then the brushed aluminum.
lol he works there
Discussion Starter · #13 ·
Re: My first mod to the V70R (DevolvR)
Quote, originally posted by DevolvR »
lol he works there
lol. I didn't want to bring it up seeing as i didnt want to get the thread closed but yes I do work there. I tried to keep it as personal as possible to not involve the company or any sales pitches seeing as this is my personal car which has no ties to TWM.
So ya that's why I can switch out shift knobs and take pics...
You guys make a great product! You did a great job keeping it personal it's just nosy pricks like me that sucked the info out of you. I don't think you need to worry about the thread. You didn't try to sell product, just posted a nice write up!
great DIY! i hate the spaceball and i'm glad the other owner already replaced the shifter else i'd be doing this. Though if i see another shifter i like better i may still do this so good job!
Discussion Starter · #17 ·
Re: (chinaonnitrous1)
^thanks
Re: (patrickd_21)
patrick,
as requested some pics of my shift knob that has the engraving. will upload non cell phone pics after i treat my interior and clean up the area a bit. The install was really easy (as i expected it to be), starting the threads was really easy too, didn't use cutting oil.
The m1 abrams feels great in the hand, and shifting is nice and smooth.
2 things i should mention- 1. in certain light the satin finish has a hint of slight bronze or gold to it. the cell pic below is worse than in to the naked eye.
2. have a vacuum cleaner on hand to suck up the shavings.
Modified by atacamaR at 2:38 PM 3-23-2010
Nice stuff Patrick. http://********************/smile/emthup.gif
You're not worried about cold weather with that? Many years ago I swore never to do a metal shift knob again because it would never get warm in the winter... My OEM shift knob is wearing out badly though...
1 - 20 of 38 Posts
