I did have a service code-overboost malfunction. So I changed the boost solenoid valve. My engine light went out, but I didn't gain any power. Take off is ok, but when I hit 2nd gear it sort of sputters. After it hits 3rd its okay again and runs fine on the highway. Does anyone think this could be the injectors??
There are far more qualified folks than me but I'd grab a vacuum/boost gauge (or use an ELM327 bluetooth OBD2 adapter + Torque android app) and start learning what's happening. You may have an ECM that could use a reset. Check the entire intake system, pre and post turbo, for leaks. I'm not thinking injectors. Just thoughts.
You have a broken vacuum line behind the cylinder head on the driver side. Comes from turbo control valve and goes to a third valve that feeds both turbos
Thanks a lot Vista winner 20. You were exactly right. I was on a mission today to find that leak, and it was just where you said it would be. Gonna replace it tomorrow. It was in a short piece of vaccum line (around 3 inches) just past the valve that connects to the turbos. Directly behind the upper motor mount. I will replace that too, the rubber is gone. Was thinkin about trading off the Volvo, and I'm so excited that I might get to put many more miles on it. I love the Swedish engineering, and it goes like a tank in the snow.
