Does anybody know how many pounds the bolt going through the top motor mount should be? As well as the ones going through the strut bar to the brackets? Putting Snabb pipe in and did not ask this before. Thanks
the long bolt that goes through the strut bar and the mounts is 58 ft lbs. The bolt that goes through the upper engine mount is 60 ft lbs.
Really..? It's just "PFT" - Pretty ****ing tight.
There's just some things that don't need to be torqued down.
Right - make it tight, then surprise yourself with another half turn. Drive for an hour and then retighten.
PFT works. lol I guess it's more second nature than anything.. When you work on cars as much as I have you sorta know torque by feel...
