1 - 2 of 2 Posts
I know this is not really a detailing question, but out of the post list this looks like the best forum. I need to adjust the moon roof on a 1998 C70 and have been unable to find any directions to to so. Does anyone out there have them or know where I may obtain them from? <br>Thanks, Brubrav 98 Coral C70
Re: Moon roof (Brubrav)
This might help you (yours should be the same as this one):<br><A HREF="http://www.volvospeed.com/Repair/sunroof.php" TARGET="_blank">http://www.volvospeed.com/Repair/sunroof.php</A><br>I've found that slightly loosening the 4 screws (dont' move the center screws) and then getting your sunroof where you want it and then tightening everything up seems to be a good place to start. After that, work on the front and then the rear. Once you get the front tight and exactly where you want it then don't touch the front 2 screws but only the rear ones. Also, the front is suppose to be a smidgen lower than the rear for hydrodynamic and water drainage. 3-4mm down from the edge of the roof on the front and 1mm or so down from the edge of the roof on the rear. Good luck! <BR><BR>
<i>Modified by MadeInJapan at 10:40 PM 6-12-2006</i>
1 - 2 of 2 Posts
