1 - 6 of 6 Posts
I bought and replaced my 4C Monroe shocks and struts about 18 months ago. The last couple of weeks, I've noticed the driver's rear shock clunks and a noticeably more bounce going on in the rear left corner while going down the road. I took the shock/spring assy. out last weekend and removed the spring. I compressed the shock and noticed no real rebound going on, although it did take some manual pressure to withdraw the shaft. I re-installed hoping the re-assembly would eliminate the clunking noise and all would be better. NOT!!! I have already replaced both sway bar links and checked and tightened all rear suspension mounting points, with no improvement. Even took out the spare tire/jack assy without improvement. Has anyone ever had a shock failure occur on these Monroe 4C shocks? Fortunately, I purchased these from FCP and I can go thru the Lifetime Warranty process. Unfortunately, I have to first purchase the shock at almost $400 and then send the suspected faulty shock back to FCP hoping that they will authorize re-imbursement. Looking for any comments, guidance or ideas from any of you out there. Thanks for you input...
What you describe is a "blown strut". Yeah, some hassle, but it needs replacing.
This is very good to know about the" FCP lifetime warranty "on their parts . I never like it when the seller determines whether it was customer abuse or manufacturing failure , lifetime warranty should mean no questions asked ! If it's bad it should just be replaced. Lifetime warranty should really be looked at carefully . Will you also have to pay the shipping cost both ways also ? Not sure if nearly double the price it worth the lifetime warranty ?
Thanks for your info
Pickle King-Here is the Warranty/Return clause from FCP:Warranty Parts / Broken Parts Return: Regardless of age, if you are not satisfied for any reason, simply return it for a refund or replacement. After 90 days from original purchase, refunds will be issued in the form of a non expiring store credit. You may return parts of kits if it is a warranty return.
Stealthy 60R-When I removed the Shock/Spring Assy. last weekend, I removed the Upper Shock Mount and the rubber looked well-no cracks or evidence of degradation. The fact that the affected side feels loosey/goosey reinforces my suspicion of a blown shock. No oil seepage or leakage seen. I have some concern about not having a matched new pair of rear shocks. It is a "daily driver" and not a track racer though. I'll probably have to fire up my VIDA/Dice and do a SUM Calibration after install of the replacement shock though. Right?
lol....I knew there was a catch. you have to buy first, then they give you store credit....but not credited back to the last purchase. basically you get forced into a revolving account.
I think it is bizarre any company would warranty consumable parts.....hell even Volvo's lifetime parts warranty doesn't cover consumable parts. But I guess that's why you pay on avg of 20% more compared to everywhere else.
1 - 6 of 6 Posts
