1 - 10 of 10 Posts
So last night I re-sealed my lens, fixed my ballaat and got my pasenger headlight running again. I got in after class at around 9:30 after it rained all day and theres moisture on the lens and water inside again. Is there another place that moisture/water can get into? Any ideas would help :D
pulled off the lens with a heat gun, scraped out/off most of the old adhesive, put new adhesive on. i used 3m windo weld superfast.
Interesting, window weld is pretty good stuff. Were you generous with the bead of window weld? My guess is you may have had an area just a little too thin. Only takes a small opening to get moisture. Did you hold the lenses clamped while curing?
I'm thinking you could maybe dunk the light in a bath of water lens facing down. Not deep enough to submerge the electronics but deep enough to cover the perimeter of the lens and check for bubbles. I've never had a sealing problem but that's how I figured I would troubleshoot in the case I ever did.
i'm gonna try some spray sealant on the back. i didn't clamp it but the windo weld was oozing out if the sides and i made sure there was plenty.
Moderator
What width of that stuff did you use? I used 3/8 with no problems ever since. I scraped out all the old crap and Ive had no problems. It gets humid here too
I have done a few retrofits. Something I always do after I get done with the job is leave one of the bulbs out of the socket for as long as it takes for the condensation to be gone. I do this if I'm sure I got everything sealed up right.
I like to use butyl tape; TheRetrofitSource.com sells it as well your local windshield repair guy.
i drove around for a bit with the back cap off and most of it cleared up. makes me think its something with the casing
Moderator
You could put a moisture absorbing pad in there, like tape it to the back of main cap
thats actually a really good idea lol
1 - 10 of 10 Posts
