1 - 1 of 1 Posts
FYI to all R GT owners, Mobil has reformulated their Mobil 1 ATF to make it JWS 3309 compliant. This happened sometime in the latter half of '08, best I can tell. Be advised there may be old stock on the shelves which is not, so read the labels before you buy.<p><b>And before everyone jumps all over me, remember that JWS 3309 is backwards compatible with a lot of older ATF specs, so some of those are also on the list.</b><p>From <A HREF="http://www.mobil.com/USA-English/Lubes/PDS/NAUSENPVLMOMobil_1_Synthetic_ATF.asp" TARGET="_blank">Mobil 1 ATF webpage</A><p>Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles. <p>Approved for Allison C-4 applications<br><b>Exceeds JASO 1-A performance standard </b><p>Mobil 1 Synthetic ATF is also suitable for use in vehicles that specify the following fluid requirements:<p>Audi G 052 025-A2, G 052 162-A1<br>BMW LA2634<br>Esso LT 71141<br>ETL-7045E, ETL-8072B, N402<br>Ford* MERCON*, MERCON V, MERCON LV<br>All 2005 and earlier GM vehicles**<br>Honda ATF-Z1*<br>Hyundai SP-II, SP-III<br>Idemitsu K17<br><b>JWS 3309</b><br>Kia SP-II, SP-III<br>MAN 339F, V1, V2, Z1, Z2, Z3<br>Mazda ATF-III, ATF-MV<br>Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9<br>Mitsubishi Diamond SP-II, SP-III<br>Nissan Matic-D, Matic-J, Matic-K<br>Subaru ATF<br><b>Toyota T-III, T-IV</b><br>Voith 55.6335.XX (G607, G1363),<br>Volvo 97340 [<i>this is not Volvo's jws 3309 atf, but its predecessor--I suspect Mobil made a mistake by not including the newer ATF part number...]</i><br>ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
1 - 1 of 1 Posts
