Hello! I have almost brand new set(4) of Volvo Meteor 16"(16 x 6.5") wheels which were on my 98 V70R that I want to use for snow tires. The Volvopart # is 9491653. My Volvo dealer is trying to be most helpful and we "think" they will fit even though the studs are on the disc rather than the disc being drilled etc. etc. Volvo itself has been MOST unhelpful(to say the Least). Any one out there ever mount a S/V 70 (98 +/- ) wheel on a new series V-50 ? What about tapered nuts- shoulder angles etc. Thanks
The hub diameter is larger on the V70 than the V50 i believe. Volvo will probably not be very helpful since they don't want the liability involved in telling you to use a wheel that wasn't designed orignailly for the V50. If your dealer is good then they can probably help you test fit the wheels?<p>In the end I went with the volvo OEM nuts.
