1 - 20 of 28 Posts
Has anyone tried CRC mass airflow cleaner? CRC is a well-established electronics cleaner brand, I've seen this stuff advertised recently and I think my NAPA carries it. I only believe the HP claim if the MAF is filthy, of course. Looking for first-hand comments on our hardware. Thanks...<p>Also thinking it might be a good solution to over-oiled K&N filters, btw.<p>Tom.<p><A HREF="http://www.crcindustries.com/auto/content/prod_detail.aspx?PN=05110" TARGET="_blank">http://www.crcindustries.com/a...05110</A><br><IMG SRC="http://www.crcindustries.com/catalog/images/Cleaners%20and%20Degreasers/05110.jpg" BORDER="0">
Re: Mass Airflow sensor cleaner (tmtalpey)
Other than an over-oiled K&N or BMC filter, why do you think you need to clean your MAF sensor? Speaking of 'oil' the claim on the can of HP gains seems like snake-oil to me.<p>LTA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tmtalpey</b> »</i></TD></TR><TR><TD CLASS="quote">Has anyone tried CRC mass airflow cleaner?...</TD></TR></TABLE><p>I've cleaned the MAF twice on my '99 S70AWD. She always throws code P1171 when it's time to clean. The treatment has lasted 2 years each time. (No horsepower gain though. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> )<p>I use CRC non-chlorinated brake cleaner. It only takes a couple of squirts for the MAF and I use the rest of the can for brake jobs.<p>I'm sure the sensor cleaner product would work too (at least for the MAF).<p>YMMV <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <br>
Re: Mass Airflow sensor cleaner (LTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LTA</b> »</i></TD></TR><TR><TD CLASS="quote">Other than an over-oiled K&N or BMC filter, why do you think you need to clean your MAF sensor? Speaking of 'oil' the claim on the can of HP gains seems like snake-oil to me.<p>LTA</TD></TR></TABLE><p>With emissions going in to air intake and following laws of physics etc... it's stands to reason i.e. scenario; been driving, stop shut off car those oil laden gasses meant for reburn through turbo sysyem and exhaust will rise to top of intake tract. That would be the MAF/Airbox, when they begin cooling and start settling down (you know that thing about air/vapors, solids and density thing) they will settle down on say for instance the surface of the MAF.. ...to include the super sensitive sensing panel. <br>(try and say that 5 times real fast)<p>The VW TDI's were having a horrible time a few years ago, VW had MAF failures mostly across the board but the tdi diesels were just dropping like flies.<br>A design change came in 04 where the MAF sensor is now in a tube which looks to be a great preventer for gasses other than the desired incoming fresh air directed to pass over the panel.<p>It's not so much of a power gainer as it is a "power restorer" and that's provided your maf was to the point you were seeing less mpg's, rough idle, lack of punch feel when getting on it, maybe harder starting.<p>It's going to be a regualr service IMO with modern MAF sensors.
Re: Mass Airflow sensor cleaner (Helmut Ranff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Helmut Ranff</b> »</i></TD></TR><TR><TD CLASS="quote">How about blasting it every once in a while with starter fluid</TD></TR></TABLE><p>The older hot wire MAF's I'd say ok but with <br>the newer. POS designs I's say no, a non - residue electronics parts cleaner iis suited much better for this.
If it's badly fouled and you clean it, you <I>will </I>get more HP and better mileage - but only back to where it should be, no "gains" to speak of.<p>Sniz had MAF fouling problems with his big cone filter intake resulting in rough running, uneven acceleration etc. After one replacment (I believe), I think he found cleaning it to be the cheaper/easier solution.
Re: Mass Airflow sensor cleaner (StaggRLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote">If it's badly fouled and you clean it, you <I>will </I>get more HP and better mileage - but only back to where it should be, no "gains" to speak of.<p>Sniz had MAF fouling problems with his big cone filter intake resulting in rough running, uneven acceleration etc. After one replacment (I believe), I think he found cleaning it to be the cheaper/easier solution.</TD></TR></TABLE><p>Can't remember, was he the one who was just cleaning it with blasts of compressed air?
Re: Mass Airflow sensor cleaner (vizwiz)
Not sure. I mentioned a solvent/compressed "air" kit that VW sells as a possible solution and didn't hear back what he used, just that it worked.<p>Don't use a compressor though, they can build up a huge static electricity charge (not to mention too much air pressure) that could damage the MAF sensor or any electronic component if it finds ground.
Just loosen the clamps before/after the MAF body and pull the whole MAF and conduit out.
Or.. I've used needle nosed vice grips in the past to grap hold of the screws on the sides and once out I suggest replacing them with standard.<br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote">Just loosen the clamps before/after the MAF body and pull the whole MAF and conduit out.</TD></TR></TABLE><p>Sounds good, but there's not clamp before the MAF body, it's screwed on to the airbox and I don't have the spaghetti fingers to get to them. I think I'll loosen the aft clamp and pull the whole air box, but won't have time for that until this weekend or next.<p>BTW, the screws on the MAF are NOT Torx-Security (6 pt) but rather 5 pt ones. Which my newly purchased handy-dandy 133pc tamper-resistant screwdriver kit does NOT include. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vizwiz</b> »</i></TD></TR><TR><TD CLASS="quote"><br>BTW, the screws on the MAF are NOT Torx-Security (6 pt) but rather 5 pt ones. Which my newly purchased handy-dandy 133pc tamper-resistant screwdriver kit does NOT include. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"></TD></TR></TABLE><p>In your kit should be a flat blade that will fit across the screw and either pushing down on top of security nub or around it, you should be able to unscrew it with one of those methods through two of the five points. Watch out if you have a lo-grade kit, as tip can break doing this. <p>Needle noze vice grips work real good to remove. ...I've done a few. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Discussion Starter · #17 ·
5-point with security nub?? <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> It's not like the secret to the universe is in there. Must be trying to keep them hamfisted non-Bosch-trained yo-yos out.<p>Anyway, can't you see the guts from the underside of the airbox? IOW, do you need to remove it to hit it with the spray?<p>Tom.
instructions call for drenching it pretty good, and repeatedly. not comfortable about letting all of that pool up closer to the intake. I'll try the flat blade trick, my new screwdriver kit is labelled and english AND german, so it must be high quality, right? LOL
You could also invest in these tools. <p>I've got this bit and some of his other tools as well and they are top quality, built to do the job.<br>Other tools are worth checking out as well.<p>The set may not be all you want, you can get the single bit if you want.<p>Check them out.<br><A HREF="http://shop.metalnerd.com/index.cgi?code=3&cat=5" TARGET="_blank">http://shop.metalnerd.com/index.cgi?code=3&cat=5</A> <p>Scroll down to see pics of set, the single bit is farther down.
Discussion Starter · #20 ·
Re: Mass Airflow sensor cleaner (Dzljet)
Wow what a great site. He makes nice stuff. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>Tom.
1 - 20 of 28 Posts
