So I solved my no-start by plugging in the transmission computer- I had connected wires in the old bundle to bypass the ignition interlock but it won't run without the computer, I was planning on mounting relays for the fog and driving lights in the ecu box so I wonder what I did wrong ?
That's odd. Did you try switching the polarity on the crank sensor? I removed all wires from the loom other than the reverse and green starter wires.
Yes, then it didn't start at all- to add complexity I did an RN swap at the same time so it is an 04 engine and gearbox i'm glad it started but it did take a while to figure out
