1 - 6 of 6 Posts
no idea and don't care. i paid too much $$ for this car to do a risky mod like that. the computer pulls boost and timing when it detects knock, so if you are using a manual boost controller, how does the computer pull boost away if it starts knocking?!?
Re: manual boost controller (p0cket penguins)
Here's a bit more constructive advice:
Send an IM Boosted S60R. He's one of the experts on this.
Blot may be able to help to. Johann is also pretty knowledgeable and should be able to give you good answers.
There are others, but I haven't gotten time to think of them.
agreed! definitely do your HW on this before attempting anything.
Quote, originally posted by p0cket penguins »
can you put a manual boost controller on an s60r. i would think it would just into limp mode.
Yes a boost controller can be used on the car to raise the boost a little over stock but with out a flash or piggy back the stock ecu will not allow more then about 17psi which is a gain from stock but not all that is capable from a flash and so on.
1 - 6 of 6 Posts
