I am getting blasted with maintenance warnings. I have a 2015.5 but just turned 47k miles. According to the manual, maintenance is needed at 50k.
You should be able to silence the one that appears on the center screen by acknowledging it.
There's also a one year time limit so maybe you're closer to that.
What is the correct way to reset the maint lights?
This method does not work on my 2015.5
You must have all doors and hood closed, also the ignition has to be in position 2. If you mess up you have to let the inst. cluster go to sleep then try again. If you press the start button twice without your foot on the break pedal the ignition will be in position 2. Once you have it set to position 2, press and hold the start button then press and hold the OK button at the same time do not release them until you see the Yellow I flash, when it flashes release both you will hear a chime.
