1 - 10 of 10 Posts
My m66 gearbox gives some noise like clicking or ratling when idling ... Sounds goes when i depress cluch pedal once i release this noise comes again ...
Any advice is apreciated
That's your dual mass flywheel. Did you recently change your clutch? If not its time for a new one with a flywheel
Sent from my iPhone4S using Tapatalk while on the toilet.
i think this could be your input shaft bearing. I just replaced my trans with a used one, but i also replaced the flywheel. The new trans makes a noise you describe that goes away when depressing the clutch
Actually i have rebuild my engine , and changed cluch , pressure plate and cylinder sleve
Afterthat i got this rnoise
Maybe everything isn't aligned or tightened completely. Or the flywheel is bad.
Did you use the single mass flywheel if so its normal.
When you did your clutch, did you use the old flywheel or put in a new one? If you're using the old one, the chatter is normal
Car is driving smosthly but i am getting this noise is it okay if i ignore this sound and drive it like this ....will it hurt my gearbox!!!!! ????
If not i dont mind this stupid noise
1 - 10 of 10 Posts
