1 - 20 of 20 Posts
2021 Volvo S60 T5 FWD
I'm looking for a new transmission for my car and I was told that there's a difference in the transmission for a turbo vs the N/A. So I don't end up snagging a tranny from an 850/S70 that's not compatible, can someone tell me what the actual differences are? Is it actually physically different? Or are we talking M56L vs. M56H which (from what I understand) only differ in terms of gear ratio?
Thanks! http://********************/smile/emthup.gif
Edit: Also, getting more specific now: how about a tranny from a '93 850. Will it fit/work?
You would have to do a FULL swap to get an 850 transmission to work in our car.
Why all the hating on the stock one for the T5? Its very respectable.
Re: (Bender)
It's got a chunk missing and was leaking. Then I summarily destroyed it further by shearing a bolt. Also, the fluid came out black the first time I drained it, so I'm kind of worried about it.
So, new tranny for me for sure. Just trying to find the best/cheapest option.
What do you mean by "full swap" anyway? And can someone educate me on what to do about the dual-mass flywheel? Do I seriously have to buy a brand new one at $700+?
Fly wheel can be resurfaced at 100 bucks unless you really have toasted it.
Re: (Bender)
That's what has me confused: I could have sworn I had read you can't/shouldn't resurface a dual-mass flywheel...
jump on volvospeed and buy just the m56 aluminum casing from someone that toasted everything else in their m56?
Re: (Impulse922)
Yeah, well, I'm still trying to find out if anyone knows what's different between the M56 transmissions between models, years, and turbo vs. N/A...
Also, I'm not so sure that my gears aren't toasted. Although, it has never popped out of gear and it feels like it shifts smoothly (as far as I know
Re: (StarmanDXE)
Quote, originally posted by StarmanDXE »
It can be resurfaced, But finding someone who will do it is the problem
You could buy a single mass flywheel from an 850r I believe, here part number 9454774 the flywheel is $275 new
Chris
Quote »
Negative - they have 22 splines on the output shaft, we have 23, it will not fit without a FULL transmission swap.
Re: (Bender)
Quote, originally posted by Bender »
Ah, Yea I just saw your other post,
And I checked in VADIS and the S60r and T5 have different part numbers for flywheels..... Well thats a Bummer, I wanted a Single Mass
Chris
Yes it would be nice to put a single mass in, BUT it would cause a lot more stress on our drive line components (much more vibration transmitted via single mass).
Blech. Well, I'm beginning to believe that putting $2k~$3k into a new transmission and clutch is silly and I'd be best just topping it off every few months or whatever and driving it until it either dies or I can afford a new car...
well every month your topping it off with what new fluid?
a Quart of redline cost $13 bucks from ipd. assuming that it doesn't need a full quart of oil. Maybe a quart will last two months.
so 13* 6 bottles needed in a year is $78 plus time and shipping or gas money to run to the store
I don't know, I mean $100 bucks a year could be used for something else.
Discussion Starter · #14 ·
Re: (Cjones16)
Nah, not every month. Maybe every 4, at the most. When it seemed to be leaking a lot for a week or so, I drained it and still got almost 2 full quarts out.
And, that 100 bucks a year you are referring to is in opposition to the one-time $2k~$3k I'd have to spend...
I am doing SingleMass Fly wheel 850R clutch
with a M56L in my XC
the m56 is the same in a 93 as its in 08
The fly wheels might be different but trannys are the same.
Only issue I would see with output shafts being differnt you should be able to use the S60R clutchs for the dual mass wheels.
Give me a week and I will let you know LOL
Re: (StarmanDXE)
Ya I guess its really not that bad of a leak, I guess I would try to stop it some how
Reading from your other post, Sounds like the Slave is going, So Idk what to tell you... A lot of money to put into the car
Re: (StarmanDXE)
Try http://www.car-parts.com .
Discussion Starter · #19 ·
Re: (Paysts)
Quote, originally posted by GuelphVolvo »
http://www.vandsautodismantlers.com/ had two M56LK's in their yard. I didn't go with them due to the cross-border issues/shipping. They quoted me $1,100US + 150US shipping to the border.
Hey, thanks. But...
Quote, originally posted by Paysts »
This site freaking rocks! http://********************/smile/emthup.gif
Re: (StarmanDXE)
Indeed. It's one of those sites you don't always tell everyone about, because if you did, all the cool parts would be gone! A true treasure for car buffs in need of rare and random parts.....at the click of a button.
1 - 20 of 20 Posts
