41 - 60 of 86 Posts
· Registered
2004 V70R M66 | 2013 C30 M66 | 1996 855 AW42
Discussion Starter · #41 ·
Cross posting some additions from the "What did you do" thread for documentation purposes.
European sport shifter conversion!
Gear shift Car Vehicle Satellite radio Steering wheel
Morimoto! (hidprojectors.com gotta go, just poor knock off morimotos)
Automotive parking light Car Vehicle Grille Hood
Japanifold!
Automotive tire Motor vehicle Bumper Automotive exterior Automotive wheel system
Automotive air manifold Motor vehicle Auto part Nut Gas
Subwoofer, to finally complete the audio
Hood Vehicle Bumper Automotive tire Motor vehicle
Reactions: ZZZZZZZ
· Registered
Discussion Starter · #42 ·
Finally replaced the front plate
Wheel Automotive side marker light Tire Car Vehicle
This happened to the KWs
Grey Line Gas Coil Automotive tire
So let's fix that with...
Tire Wheel Motor vehicle Automotive tire Automotive design
Automotive tire Aircraft Tread Airplane Rim
NOW... the REAL fun begins.
Specially made 19T hybrid, the turbo this car should've been equipped with as standard.
Automotive tire Motor vehicle Asphalt Rim Automotive design
Wheel Tire Automotive tire Tread Hubcap
Motor vehicle Automotive tire Automotive design Automotive exterior Hood
Automotive tire Motor vehicle Automotive design Automotive lighting Tread
Car Hood Motor vehicle Automotive design Automotive tire
1010 kg/hr! Outflows stock K24 with ease on this tune, though, it still needs some tweaking.
· Registered
Discussion Starter · #43 ·
Messed around with wheel options.
SPA XC60 Y Spokes - 18" 23lbs!
Tire Wheel Car Vehicle Automotive parking light
BBS DTM - 17" 17lbs!
Wheel Tire Car Land vehicle Vehicle
What I can say is both of these wheels will likely make a permanent appearance on this car at some point.
Reactions: bensoda and ZZZZZZZ
· Registered
Ok I have a few questions lol. How was the experience going from the KWs to brand new 4C? I assume you still prefer the KWs? Where'd you source the turbo from?
Those XC60 wheels look nice! I've always loved BBS wheels but personally, I just feel like 17s look small on these cars. Weight savings sure is nice though.
· Registered
Discussion Starter · #45 ·
Honestly it’s a wash, there were things the KWs did better, and there are things about 4c that makes for a better daily. The only reason I went back to 4c was the massive delay to get replacement springs from KW… that being said I do not really feel as compelled as I thought I would be to swap back to them.
I too shared the opinion about 17” wheels on these cars until I got out of the realm of pegs. Also makes for more affordable tires. BBS are forged, plus extra sidewall.
Turbo was put together in house by Will
Reactions: bensoda
· Registered
fantastic! Did you also purchase the 19t from him or sent it in for a rebuild? Still tuned by gustav?
· Registered
Discussion Starter · #47 ·
· Registered
I must say, after experiencing this car in person, it's truly fantastic. The 19T walked away from me (still on stock K24, stock tune) while getting on the highway and it matches the car so well. That combined with great tires, a quaife, and 4C makes it an amazing GT car that can carve some roads in the mountains.
· Registered
Discussion Starter · #49 ·
Delrin and poly
Tire Photograph Wheel Vehicle registration plate White
Tire Wheel Automotive tire Tread Motor vehicle
Tire Vehicle Automotive tire Wheel Motor vehicle
Fresh alignment
Green Handwriting Font Line Gas
Needs more front toe, to be addressed at a later date. Oh how crisp.
· Registered
'05 V50 T5 M66, '04 XC70, '98 V70 AWD, various junk from other brands
· Registered
Holy siht Luke, I have those EXACT same XC60 takeoffs…. Intended for my V70.
I came in here to see if you had any details about the quaife performance and saw this. Not installed yet as I never completed the spacers for them (and the tires on my pegs are still fine). Worst thing about these is the backspacing, if you bore them and bolt right up they will be DEEP in the wheel wells….. I got 25MM spacers for the XC60 bore, will open up the hub side to the V70 dimension, and run studs on mine (eventually).
crazy though, did not expect to see ANYone put a P2 on these wheels. You’re gonna make me do a 19T now LOL
· Registered
Discussion Starter · #54 ·
How difficult was the Delrin install? Seriously considering a set for both my P80 V70 and P2 XC70 after hearing how much of a difference they make to handling.
Just got my BNE delrin bushings this week! Was thinking about installing them this weekend put probably going to wait till I do more suspension upgrades.
They are fairly easy if you go about it the right way. Best way (and the way I did a few at Volvo) was to core the rubber material using a saw or drill, and then hammer the bushing sleeve (plastic) in on itself, they pop right out. I do one at a time. You can also remove the subframe and press them out using conventional methods. The new ones can be driven in using the bolts and some spacers.
Actually thinking these are going to go on my C30 at this point, I should have a set of DTMs ready for this eventually and would rather return to 17" wheels on this car. I don't really see any point in spending $200 on spacers that will only be useful for one set of wheels on my specific car. I saw someone put them on a black C30 and was convinced that's where they belong... in my fleet anyway.
The quaife is fantastic, was basically the first modification to the car and everything else after would not have been up to par without it.
Reactions: V50_M66
· Registered
Do you have to get an alignment afterward? Or is that only the case if drop the whole subframe?
· Registered
Discussion Starter · #56 ·
I would absolutely recommend it, considering it's the only thing your adjustment is bolted to. It might be fine, but I tend to be very particular about alignments. I do them basically anytime something is changed that has the ability to affect alignment angles.
Reactions: bensoda
· Registered
The Quaife is a game changer in my dad's NA V70
My S60 without is really disappointing compared to his NA and my R with it.
· Registered
Discussion Starter · #58 ·
Cleveland, OH trip to pickup a new bumper. It was cheaper to buy this fairly nice bumper and fogs than buying paint
Car Vehicle Daytime Sky Automotive side-view mirror
Car Land vehicle Vehicle Sky Grille
That was a quick 1,000 miles
· Registered
Discussion Starter · #59 ·
What do we have here!??
Tire Wheel Automotive tire Tread Hubcap
· Registered
41 - 60 of 86 Posts
