21 - 28 of 28 Posts
2004 V70R M66 | 2013 C30 M66 | 1996 855 AW42
Discussion Starter · #21 ·
Just dawned on me this is my 3rd 426 car... clearly I have a thing for Silver.
Looks great - which hf gun did you use? Where did you source the sealer / base / clear? Curious to know more about the process if you don't mind sharing.
Discussion Starter · #23 ·
I used the 17.99 one and added a pressure regulator. They market it as an HVLP gun but I didn’t get good flow from it until I went up to 35ish PSI.
Basically, I knocked all the old clear off the bumper with 200 grit, followed by 400 grit to smooth, then I applied sealer, base, and clear. I should’ve done a layer of primer then 800 grit and I think the finish would’ve been smoother, but this is still pretty acceptable I think.
Reactions: lawdogg
Discussion Starter · #24 · (Edited)
I’d probably recommend spending a little more money and getting the Astro Pneumatic off Amazon; the HF gun was fun for a first time but I don’t see it lasting through several sessions
I sourced the materials from a local paint supplier, it was pretty pricey (250ish) but most of that was for the clear, sealer, and various other hardeners/reducers… which I can use again on the next project
Reactions: lawdogg
I would agree with using a sandable primer for any 2 stage painting project, especially a bumper. I got mediocre results on my first 2 stage bumper and more prep would have helped a lot.
Discussion Starter · #26 ·
Automotive parking light Wheel Car Tire Vehicle
Mounted!
Wheel Automotive parking light Tire Car Vehicle
Ahh that's so much better... the enkeis also made a return!
Tire Land vehicle Car Wheel Vehicle
  • Love
Reactions: lawdogg and JaredR
Discussion Starter · #28 ·
Reactions: bensoda
21 - 28 of 28 Posts
