1 - 20 of 29 Posts
2004 V70R M66 | 2013 C30 M66 | 1996 855 AW42
Hello all, some might recognize me as slowvagn (formerly boostedxc) on Instagram. I formerly had a manual swapped XC70, lowered, with a B5244T5 and Rolling Motors K24 hybrid. I had the car for around 80k, and had a lot of fun with it, I was fortunate enough to give it one last hurrah to Cape Cod with @ScottishBrick and @JaredR. Upon returning to the humid south, I realized I was ready for something different. A friend of mine traded me this lovely automatic (at the time) 426 04 V70R, with some goodies including a manual swap w/ quaife and KWs.
Fair warning! This is a picture heavy post!
Cloud Car Tire Land vehicle Sky
First order of business was removing the BC Coilovers that the car came with in favor of some KWs!
Tire Wheel Aircraft Automotive tire Motor vehicle
Test drive on the dragon proved a success! Even the co-pilot agrees. These coilovers are amazing and WAY better than the BCs they replaced.
Tire Vehicle registration plate Wheel Car Vehicle
Those silver headlight bezels just aren't doing it for me... and the projectors needed some adjustment anyway. Let's fix that
Automotive parking light Car Sky Vehicle Land vehicle
MUCH! Better!
The automatic in this car was shifting okay, and my original plan was to leave it that way until it got cooler in the Fall. Unfortunately, the P/S pressure line was failing to seal at the pump due to the flare being damaged, since it requires subframe removal (and I have AC at the shop)... time to get 3 pedals! This car is my 4th overall manual swap, so it was relatively straight forward. While I was at it, I went ahead and swapped in a fully stripped down and resealed B5244T5 I had laying around. This car had no signs of cracked liners... but might as well improve it a bit (I don't believe in shims)
Tire Automotive tire Vehicle Motor vehicle Aircraft
AW55-AWD and B5254T4 removed.
Car Speedometer Vehicle Motor vehicle Gauge
Pedals and cables added
Automotive tire Gas Machine Engineering Automotive wheel system
Hood Automotive tire Motor vehicle Automotive design Bumper
Goodies!
Torque your VVT Hubs people!
Tire Wheel Vehicle Motor vehicle Automotive tire
Engine and new M66 mated and ready to go on the subframe with new mounts... and most importantly that new P/S line!
Automotive tire Motor vehicle Automotive design Hood Vehicle
Continued below!
Discussion Starter · #2 · (Edited)
Automotive tire Road surface Motor vehicle Asphalt Walking shoe
Figured it was a good time to install a do88 to keep those temps down, it's hot as hell down here!
Car Vehicle Hood Automotive tire Motor vehicle
Now that the engine and transmission are back in the vehicle, wiring! This consists of wiring up the reverse lights (I opted to run a wire all the way to a relay in the rear of the car instead of spending big money to reconfigure the vehicle's CEM) and the clutch pedal position sensor.
Tire Wheel Car Vehicle Automotive tire
A/C Recharge... and finally test drive after flashing the manual ECM file!
Cloud Speedometer Car Vehicle Sky
WOW! This is the first car I have owned with an LSD, and compared to my stock '05 S60R I had, this thing is awesome. It grips for days, and you can whip into corners confidently knowing you can pull right out. Overall, the swap took me less than a weekend, basically one full day of working. It helps that I've done this a few times and am familiar with the wiring, etc.
I'm quite happy with this wagon. I really love the factory HU-803 compared to the HU-850 in the S60 or the aftermarket unit I had in the XC. Eventually it will be getting a sub, and Dynaudio goodies! I quite enjoy the factory exhaust currently, after having loud cars, being able to get in a true sleeper is nice.
Wheel Tire Plant Car Vehicle
4th of July!
Now for some cosmetic love...
Tire Car Wheel Plant Vehicle
The trim was quite faded due to years of being an outdoor car. Above is post fix, I'm a big fan of the 04 contrasty trim look, especially on silver. I decided to use Duplicolor's trim paint in black, which I have had great success with on the XC cladding.
Now that that's done... time for some pretty pictures!
Wheel Tire Car Vehicle Land vehicle
Automotive parking light Cloud Car Wheel Tire
Pegs have made a return, the Pilot Sport 4 AS on the Enkeis were well past their life! Will be returning after some paint work and an opening with the tire installer.
  • Love
Reactions: rockstarjake79
Recently, one of my favorite routes to take in this R is 129 (Dragon) through Robbinsville, then up 74 to the Blue Ridge parkway. Really some breathtaking scenes, and the parkway can be quite fun.
Automotive parking light Cloud Car Sky Land vehicle
Tire Wheel Cloud Sky Car
Sky Cloud Car Vehicle Speedometer
Now.. for that ragged airbag cover. Recall time! Always fun going to your former place of employment as a customer.
Automotive parking light Tire Car Vehicle Wheel
Steering part Motor vehicle Vehicle Automotive design Steering wheel
Ahh, that's better. Call me crazy, but I prefer this fresh new airbag. After attending a mandatory Volvo class on SRS components, I am not swapping the cover. Weakening the clips that hold it to the bag module could create a projectile that is likely worse than the original issue that warranted the recall in the first place. You can spare me the tutorial, and you can do what you please but I'm choosing the safe option.
Me too.
How is the feeling of spaceball shifter when compared to the regular one? Any noticable difference in responsiveness?
Do you mean vs the automatic? Well it feels like about twice the car without the torque limiting.
As far as the actual shifter, not a huge spaceball fan. It will be removed and replaced with a genuine volvo sport shift knob and boot.
Me too.
I've had a better experience with the spaceball in my S60 than the base M66 shifter in my 850R. The shift cables bind with every M66 I've closely investigated and I had to do a lot of work on my base M66 shifter to get it to mask that problem as well as the spaceball does. That said, I know I am one of extremely few people in the states with a base P2 M66 shifter in anything and mine is the only one I have ever experienced, so I am not sure if there was just something wrong with mine or if this is normal.
A complete swap in less than a weekend... I can only hope to be as efficient as that one day lol. Nice job car looks awesome!
2002 S60 2.4T, 2015.5 XC60 T6 AWD R-Design Platinum
your posts make me miss having a big garage and 0 kids in college.
Reactions: Coop R
Discussion Starter · #13 ·
Thanks for all the love!
@s60_project on IG
Hi. I also did a manual conversion also. You can manual swap the CEM very easy with less price than Hilton. what i did. Found a guy from UK who remotely unlocked the CEM Pin code for 100 pounds. Go into VDASH and change configuration for CEM from auto to manual for 40 euros. so for a total cost of 150 euros i manual swapped my cem. Just need to connect two wires from the gear selector and you will get back the rear reverse lights and parking sensors oem style.
Discussion Starter · #15 ·
Wasn’t going to use hilton. I have the ability to get the PIN using CAN dumps from vida, my subscription is expired and I am waiting until we have a customer car that needs vida to do it.
Cool to find you here on Swedespeed, was already following on instagram. Lovely car dude!
How do you find the KW's? I want to pull the trigger on a set, but can't seem to find much reviews/experiences with them.
Discussion Starter · #17 ·
VIVA sells them I think, the previous owner of this R bought them used but never installed them, before that it was on BCs which were less than stellar
They are far superior to any other option
The BCs made stock P80 suspension feel luxurious.....
Discussion Starter · #19 ·
Discussion Starter · #20 ·
In other news... decided it was time for a fresh front bumper. Picked up a spray gun from harbor freight and decided to use commercial materials instead of spray cans... It's not perfect but it went much better than any rattle can job I've done. It's still way better than what is on the car now.
Prep! (with lots more off camera)
Automotive tire Asphalt Motor vehicle Road surface Bumper
Sealer!
Tire Car Wheel Hood Automotive tire
Couple coats of base
Couple coats of clear
Hood Vehicle Naval architecture Motor vehicle Automotive design
Hood Automotive tire Automotive lighting Motor vehicle Automotive design
Hmm, I'm pretty happy with that for a first time. Could definitely be better with some higher tolerance equipment and technique adjustment. But.. a bumper is bound to see damage so for now this is an improvement!
I will mount it up tomorrow and see how the match turned out, I'd imagine pretty close since 426 is a pretty easy one
This bumper came off a '06 Black sapphire car, so the plastic lower trim is not present. I'm considering installing a lip that is textured and black to give it an OEM look.
Reactions: lawdogg and bensoda
1 - 20 of 29 Posts
