Are there lowering springs available for the V70R? I don't want to lower it too much, and do not want to mess up the 4C active suspension.<br>THX!<br>
Re: Lowering Springs for V70R (basscotte)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>basscotte</b> »</i></TD></TR><TR><TD CLASS="quote">Are there lowering springs available for the V70R? I don't want to lower it too much, and do not want to mess up the 4C active suspension.<br>THX!<br></TD></TR></TABLE><p>Ok, without sounding like too big of a wanker, do a search on this. There is literally thousands of posts, and much debate. I'll sum it up quick below, but there are pluses and minuses to each and you'll definitely want to read.<p>TME Springs through IPD are the least drop. Supposed to be between 1/2" and 3/4".<br>Evolve makes springs for both. <br>I know there are several other brands out there.<p>They will not mess up the 4C. If anything, they'll help it. This is pretty much universally recognized. <p>Good luck.
IPD sells springs from TME which only lower the car 1/2-5/8 inch. Order them with the anti sway bar and you will be very happy. I have a front lip on my car and haven't scraped yet!<br>DAn
Re: Lowering Springs for V70R (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">Ok, without sounding like too big of a wanker, do a search on this. <br></TD></TR></TABLE><p>Bascotte, there are 2 ways to do a search on this forum, the first is to use Swedespeed internal search thingy which you'll see in the upper right-hand corner of the page. This will get you some stuff, but reliably seems to miss posts/topics that it should find. <p>the other approach is to use a customized google search engine, at: <A HREF="http://www.google.com/custom?domains=forums.swedespeed.com&sitesearch=forums.swedespeed.com" TARGET="_blank">http://www.google.com/custom?d...d.com</A><p>I haven't used this alot myself yet, but it may be better, and at least between the two you'll probably turn up more stuff of interest. <p>
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>basscotte</b> »</i></TD></TR><TR><TD CLASS="quote">Are there lowering springs available for the V70R? I don't want to lower it too much, and do not want to mess up the 4C active suspension.<br>THX!<br></TD></TR></TABLE><p>TME's part# 1570 $348/set would be your best bet for what you are describing. (lowest drop)<p>We are sold out at the moment, but the container is on the water and due here 2nd week of May, so 3-4 weeks and by then our new installation facility should be open so we can install them for you as well. <p>We also have the EIBACH (same as HEICO/EVOLVE) springs in stock if you want to go lower. In fact, we are overstocked on the HEICO V70R spring application only ( made by Eibach / same specs) and we could do those for $590 installed. ($250 for the springs $340 installation) This is also a good time to throw in the sway bars and HD end links if you are considering them as you will save about $100 on the installation if you do them all together. You would need to get an alignment done afterwards ( we can arrange this and have it done when you pick up the car if you prefer), and I guarantee you that you won't leave our shop with your headlights all messed up from an imporperly performed suspension calibration! The Eibach V70R springs are labeled as HEICOS and are origianlly $539 set and are a nice blue instead of red liek the Eibachs. <br>These are also availabe at this special price while we are overstocked on our website or by calling 1-800-444-6473.<br>
Re: Lowering Springs for V70R (kenschel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kenschel</b> »</i></TD></TR><TR><TD CLASS="quote">...the other approach is to use a customized google search engine, at: <A HREF="http://www.google.com/custom?domains=forums.swedespeed.com&sitesearch=forums.swedespeed.com" TARGET="_blank">http://www.google.com/custom?d...d.com</A> </TD></TR></TABLE><p>Or just add <B>site:forums.swedespeed.com</B> after your search terms in most any search engine. <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0"><br>
Re: Lowering Springs for V70R (Scott Hart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Scott Hart</b> »</i></TD></TR><TR><TD CLASS="quote">In fact, we are overstocked on the HEICO V70R spring application only ( made by Eibach / same specs) and we could do those for $590 installed. ($250 for the springs $340 installation) </TD></TR></TABLE><p>Hooo! Good deal on the installation. Scott, feel like coming to NY?<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
