I pulled the lower one, came right out. However when I went to check the plug the wires just fell out like it wasn't plugged in all the way.
Now I can not for the life of me see where it plugs in, what should I look for?
Is it on the sub frame? On the body near the inner steering boot? I can see the upper O2 plug fine, is it next to it?
I believe it plugs into another wire. So, see if you can find a wire loom coming from the engine-bay, running down with the downpipe. Sorry I can't be more specific, it's been years since I've had to do it.
On an 04 - they both plug in side by side underneath the MAF to turbo air hose. just took mine off Sunday night.
They have an extra release clip on the plug normally and shouldn't "fall off" unless it's been off before and didn't get reattached properly.
Sent from my BBB100-1 using Tapatalk
I found it, it had come loose from its clip and was stuck under one of the power steering lines. I had to zip tie together as the wire clip was missing. Started it and cleared the code, so far so good.
