They aren't terribly difficult, but no one here knows your mechanical ability. I can do both in about 20 minutes with a lift, but I've been doing this a while.
While I will admit it takes me longer than 20 min. to do both sides the time extender for me was the replacement of the ball joint. They came out easy enough but because I don't have the tool to press them back in, it took awhile. Give it a few hours with a nap between sides.:)
Did mine last fall. An afternoon job, for first-timers. Easier to get out, than put back in. Lowering the LCA enough to get the ball joint back in is the hard part. You can use a large cargo tie down strap to pull the LCAs down. Also, don't pull the inner CV apart getting the axle back in.
Are you doing just the control arms, or the ball joints as well?
Tricky part is reassembly, in my experience (done them twice)
