The drivers side lower ball joint came off with no problem. I had to get a bit aggressive with a Dremel and a pry bar for the passenger side. Can someone tell me what size/thread the lower ball joint nut is for a '68 142? I bought some 1/2 - 20 but its a bit small, assuming 9/16 - 18 but wanted to confirm without taking the other one off again.
Also, does anyone have some tips to keep the ball joint from spinning while tightening? I tried using a pry bar against the caliper bracket that connects the two ball joints but couldn't keep it from spinning.
