I have a 1974 164E, and the lower A-arm bushings need to be replaced. I checked ipd and they've got them for the 140 . . . <p>Are the lower A-arm bushings the same for the 140 and 164?<p>And for that matter, are all the front suspension bushings the same between the two models?<p>Thanks in advance.
Re: Lower A-arm bushings? (R Salesman)
Lower bushings, sway bar bushings, and both upper and lower ball joints are the same as a late-'69 and onwards 140. Upper bushings and most of the steering parts are different other than the center tie rod ends.
Re: Lower A-arm bushings? (Phil Singher)
Lee,<p>Consider replacing all older suspension components as once you get everything apart...<p>All 164 stuff is still available.<p>George Dill
Thanks for the help guys. <p>I think I'm going to order up the complete polyurethane bushing kit for the front end from ipd see <A HREF="http://www.ipdusa.com/ProductsCat.aspx?CategoryID=1305&NodeID=4035&RootID=629" TARGET="_blank">here</A>. Obviously I'll confirm with the ipd guys that everything in the kit will work on the 164.
