1 - 1 of 1 Posts
I helped a friend do a timing belt change today on a 2002 S60. It went okay with a few bumps I'll elaborate on later. My main question is: Now the coolant low-level light is on. When we moved the coolant overflow and power steering tank, I noticed the wiring harness was pulled pretty taught. Do you think we did damage? Can this be easily fixed or do we need to buy a new reservoir with the sensor? Yes the coolant level is correct.<p>On to lessons learned: When we pulled the crank pulley, we used a steering wheel puller and went a little too long and this pulled the timing belt cog out a little before we recognized what was happening. So when we reattached things we just figured the tightening the crank main nut would seat everything. WRONG!!!!! After we had every thing back together, we started it up without the front cover on to make sue all was well. We noticed the belt kept moving towards the front of the engine on the tensioner. We kept thinking we did something wrong with the tensioner, but that was NOT THE PROBLEM. We ended up pulling the harmonic balance again, and then using a sleeve, hit the timing belt gear, and noted it move back about a quarter inch, (just enough to put it back into proper alignment). After putting it back together all was well (except for the coolant light). Any ideas on the coolant issue?<p>Jerry<br>
1 - 1 of 1 Posts
