After reading a bit of what search found me, i felt it time to explain my issues and take a poll on where to go next. My pal Chris and I have been building up my 96 850 R wagon for the last several months, and finally installed a digital boost gauge about a month ago, and were kinda shocked at the low numbers. The car is pretty much at stock levels, solid 10psi range ( shift spikes are in the high 11s ) This was before and after some of my recent mods... heres my list:
96 850R wagon
IPD ecu ( should be in the high 15s psi- Proven 17psi in Chris 96 R)
3" True CAI ( cone filter sits below the battery tray )
MSD blaster ignition
IPD wires with new cap and rotors
3" Downpipe
Magnaflow Race cat ( ceramic substrate)
2.5" cat back with high flow "turbo style" muffler
TurboXs BOV
Here's what ive done:
Removed and inspected ALL charge pipes
Replaced all found vac leaks ( there were 2 minor ones) a quick starter fluid scan of the engine says no more..? )
Replaced both vac lines to the BCS
Replaced BCS with a junk yard one, then again one from our T5 wagon
Tightened up spring pressure on BOV ( it had a small amount of loose "play" under heavy throttle *not under load*
Hand felt tension on the wastegate actuator ( felt like decent spring, but perhaps need to replace? )
Next step IMO would be swapping the WA
Perhaps there are some more ideas out there?
I feel like ive read all the common low boost threads that a basic search could find, but i'm also noob-tastic.
Thanks super much!
-Grae
96 850R wagon
3" Downpipe
TurboXs BOV
Thanks super much!
-Grae
