Hi Everyone,<P>Here is my story: A couple of days ago, I noticed that a rubber elbow that attaches to the passenger side of the intake manifold (between the manifold and the power steering pump) had worn away and become comletely disconnected. This made sense beacuse my car was only getting around 4-5 psi of boost. After hours of trying, I was unable to get the new elbow in there, so I ran a completely new vacuum line (along a different route). After doing that, I noticed no difference in boost pressure (still around 4-5 psi). <P>After this, I decided to try out my new Dawes Devices manual boost controller. To install it, I disconnected the line from the wastegate, pluged that into the MBC, and put a hose from the other end of the MBC into the wastegate (I think this is how it is supposed to be installed, but correct me if i'm wrong, please). After installing the MBC, i noticed absolutely NO difference, so I decided to adjust it. After adjusting the MBC as far as it would go, i STILL only get around 4-5 psi. I am very frusterated w/ the whole thing, and I'm out of ideas. Do any of you have any ideas as to what I should try next?<P>I look forward to your responses.<BR>-Greg
