Ok, I just did my PCV system, replacing and or cleaning where needed. While I had the intake off I cleaned the throttle-body and manifold. The reason I did this is I was using 2 to 3 quarts of full synthetic between changes. Well anyway I am, AGAIN, a quart down with about 1000 miles since the service. <p>I also put a boost gauge in about a month ago of so. It was a SunPro, but I noticed only about 10 psi and I took it off the red line from the TCV. So today I unstalled an AutoMeter ProComp Ultra-Lite and moved the line to the intake as I should and I am still only getting 10 psi.<p>Could the oil use be as a result of a failing turbo or what? Any help will be appreciated.<p>By the way, she has 104000 on her, she's an '04 and a GT. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: Low boost and excessive oil use!!!!??? (Overun73)
What gear is the GT transmission in when you're doing your pulls that max out at 10 psi?<p>Have you checked to see at what pressure the wastegate is starting to open at? Should be 6-7 psi if stock, but cand (and should) be adjusted up to 8-9 psi.<p>Have you tried a compression and leak-down test?<p>When was the last time the sparkplugs were replaced and with what type of plugs?<p>Cheers,<p>J
Re: Low boost and excessive oil use!!!!??? (soupandspoons)
I am in at least 3rd gear.<p>The gate is moving around 8 psi.<p>I have not done a compression or leak-down (and I don't know how to do the leak-down)<p>And I an not sure when the pluges where last changed, I got the car 5 thousand miles ago, but I know they NEED to be changed and they are currently Bosch Iridiums. I am trying to get the normal maintenance items done that I know where neglected but I just Haven't gotten to them yet.
At you current rate of oil usage (1 quart / 1000 miles), assuming that there isn't an obvious oil leak on the oil lines to and from the turbo or one of the engine seals, is bad rings and/or valve seals, which is $$$$$$. To put this in perspective, if the car was in warranty, you would be looking at a new engine at your current usage.<p>I think that you need to take it to the dealer or your local competent indy mechanic and get them to track this down. If it was me, I would change the plugs and do a compression test while I'm at it. That way, you might be able to at least trace it to a cylinder(s).<p>Best of luck,<p>J
i had a similar problem - was going through a quart every 1000 miles - and the dealer did indeed replace the engine. i never got a detailed explanation of what was causing the problem, but i guess the dealer doesn't do engine rebuilds so they didn't care. covered under warranty thank god.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Overun73</b> »</i></TD></TR><TR><TD CLASS="quote">Ok, I just did my PCV system, replacing and or cleaning where needed. While I had the intake off I cleaned the throttle-body and manifold. The reason I did this is I was using 2 to 3 quarts of full synthetic between changes. Well anyway I am, AGAIN, a quart down with about 1000 miles since the service. <p>I also put a boost gauge in about a month ago of so. It was a SunPro, but I noticed only about 10 psi and I took it off the red line from the TCV. So today I unstalled an AutoMeter ProComp Ultra-Lite and moved the line to the intake as I should and I am still only getting 10 psi.<p>Could the oil use be as a result of a failing turbo or what? Any help will be appreciated.<p>By the way, she has 104000 on her, she's an '04 and a GT. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><p>I have 102k on my VR and just returned from a 2500 mile trip - total oil usage was about 1/4 of a quart on that trip. I've had the car from new and am pretty OCD about maintenance (M1 every 4500 miles). <p>Are you seeing any signs of usage? Smoke? I would estimate at least one cylinder has failed rings. The turbo sounds like it's shot but should not contribute that much to the heavy oil usage. As mentioned, time for a compression test and more than likely an engine rebuild. <p>Hope all goes well. You may want to look for a used R engine. Talk to Chilled Man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>soupandspoons</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Have you tried a compression and leak-down test?<p>J</TD></TR></TABLE><p>With that much oil leaking/burning, you should definitely hit these two tests up first!<p>I assume you have no oil puddles on the ground.
