1 - 20 of 30 Posts
I am in the process of parting out a 2000 Volvo S80 T6.
With the body damage, random electrical draw that kills the battery, missing corner lights, and rough interior, it's not worth trying to fix - so I am parting it out.
I figured the best way to do this would just kind of put parts and prices as I go along on disassembling the car.
If you have any questions or need anything, just post up below.
I tried to be reasonable with the pricing, but if I am not - PM me and let me know.
Buyer responsible for all shipping costs - Located at ZIP 70510
Fuel Rail with Injectors - $45
Undamaged Intake Accordion Hose - $20
Mass Airflow Sensor - $20
Intake hardpipe from Accordion Hose to Turbo Inlet pipes - $30
2 into 1 Intake Pipe from Turbo Compressor to Intercooler (Includes the Twin Charged metal plate) - $20
Exhaust Camshaft CVVT Valve - $20
5 Coils (6th connector broke, threw it away) - Definitely used, all for $15
Discussion Starter · #2 · (Edited)
Moar goodies. As mentioned in OP, shipping is not included in prices. I try to make it as reasonable as possible cost-wise however.
Starter - Tested Good on 2 Different Test Benches - $35
Taillight Pair - $70
Underhood Fuse/Relay Unit (PN# 9494207-petrol) - $40
includes the following relays:
2x 9441158 / 2x 9441160 / 4x 9441161
Grille (Mounting tabs intact!) - Fits Years 1999-06 - $35
Cooling Fan - PN# 0130303909 - $75
Engine Computer - PN# 0261206272 or 09470738 B - $20
TCM - PN# P09472349 - $15
A/C Compressor - System was blowing cold air and was full of refrigerant prior to disassembly - $50
ABS Module - Car did not throw an ABS code, however, I always consider these to be cores! - $40
I didn't take a straight on photo of the wheels yet, but here is a picture of the car before we started disassembling it, you can see the wheel on the driver front
Keyfob - $8 shipped
Brake master cylinder with resevoir - $20
Exhaust manifolds and turbos. I would consider these cores but only one has significant shaft play. As pictured $100
Turbo compressor piping - in and out. $25
Also guys - let me know if there is something you need!
Sent from my SM-N900V using Tapatalk
Pulled the transmission tonight.
Although the car shifted from 1st to 2nd well enough, I was never able to get the car out on the road for a test drive.
As such I am selling this as a CORE transmission.
I would be willing to ship directly to a rebuilder on your behalf - so if you wanted to do a Triple Edge transmission rebuild, I could send it to them if you've made prior arrangements.
Asking 300 dollars plus shipping for the core trans (2000 T6 - 4T65EV-GT)
what style thermostat housing does this have?
I can take a picture for you. It was a 2 piece housing as i recall
I'm hoping it's like this
I wanna swap mine out with the older style so I can get at the intake bolts better
Sent from my SAMSUNG-SM-G870A using Tapatalk
Yeah not the one I need thanks though
Discussion Starter · #16 ·
Bump - some more parts.
Steering Wheel - $15
Gear Selector Unit - $20
Airbags (Drivers side has cruise control switches) - $45
Gray Dashboard - $50 (either pickup only, or i will bring it to a crating shop - buyer will be responsible for packaging costs and shipping costs)
Lots of parts and trim pieces still available!
1 - 20 of 30 Posts
