Well I knew it would not be perfect forever. With 324K on the clock and 240 of them with a full IPD tune, I am getting a load noise from the valve cover. Car runs but not sure what it could be. Any ideas ?
Tapping? Does it increase with engine RPM?
Could be a lifter going bad. Not exactly a death sentence for your motor. If you can do a timing belt, you can pop off the cam cover + cams and change the offending lifter... or just replace them all since it will be hard to track down the faulty culprit.
PS: What model car?
Yes it does and thank for the input.
2000 XC. Well since it will be open any suggestion on what replace while its open ?
Check your oil level first, low oil=noisy valve train
Last week when shuffling cars in the driveway I started the car up and the noise was gone. I was waiting till next month to have it towed in thinking the worst. Since the noise was gone I decided to dive it to the shop on Friday. Got the call a bit ago that and oil change ( always synthetic )and still no noise. The guess was a stuck lifter. So will let it go and fix a few other probs that you have with 324K
Replace rear hatch release to repair a non working license plate light
Replace revers switch on transmission to correct no working back up light
Replace broken simi function drivers seat adjustment panel and switches
Thanks for all the input and amazed at how hard this car has been driven ( 48 sates and 7 cross country road trips) and still id fun to drive. In Jan I will do the timing belt water pump ect
