Bummer about the issue, and I don't have a specific answer, but you could take the opportunity to make it manual instead. Unless, of course, you prefer an automatic.Hi, I have a question on transmission replacement for 99 V70R. I have 4 speed. Do I have to go with 99 awd only like V70, S70 or XC70 replacement trans or any AW50-42?
I would love to do manual swap but the price I got was 3x what I paid fro the whole car.Bummer about the issue, and I don't have a specific answer, but you could take the opportunity to make it manual instead. Unless, of course, you prefer an automatic.
I did stop by at LKQ to check it out and found hole in it .Bummer. But at the same JY there is 2000 XC with approximate 150K. Will that one work??? And I found one in Indiana for $400 with 130K already pulled outc of 1999 V70 AWD.What about that R at the JY ? wasn't that a 99 ? I also can't say for sure which models are compatible. Go on wikipedia and look up Volvo V70. They list all the models, years, engine and transmission types for all the V's throughout the P80 lifespan.
Thank you for clarifying that.That Indiana trans is the one to use. 2000 XC are also 4 speeds but the trans is slightly different.
SB, that would be the same for trans from 2000 S70 AWD Part Number: 1208942, No go correct?That Indiana trans is the one to use. 2000 XC are also 4 speeds but the trans is slightly different.
Thanks again, Here is the listing on Ebay and it is local to me.Let me do some vin split checks in vida and report back
Do I get your blessing/green light to pull the trigger?It looks like the transmissions may be the same, but I am seeing different torque converters for LPT and HPT, so you may need to swap yours over. Not very hard really.
PNP switch changes, so basically keep all the electrics from the car and put them on the new trans.
Should be fine.Do I get your blessing/green light to pull the trigger?![]()
SB, ThanksShould be fine.
PNP switchDoes nothing physically change on the trans for the 7 position shifter in 2000?
