1 - 9 of 9 Posts
Df1406
· Registered
Discussion starter · #1 ·
Recently I've been experiencing a loss of power while driving for up to 4 seconds. When. It happens it just seems like there's an air bubble in the gas line cause if I press the gas pedal during the loss of power nothing happens. I suspect that it may be the fuel filter or a build up in the gas line any suggestions on what it could be or what products to use or stay away from?!?!
year, model, miles on the vehicle? could be a fuel pressure sensor issue...
Most likely fuel pressure sensor.
The exact same thing happened to me.
Simple Fix.
Could be many things. Get a code scanner or take it somewhere that can scan for codes... fuel pressure sensor, fuel pump, MAF, ignition coils all possible culprits.
1 - 9 of 9 Posts
