1 - 2 of 2 Posts
2003 Volvo XC70. SRS light problem.
Code reads Driver airbag resistance too high.
Swapped in a different airbag today and reset the light and it came back on after about 10 seconds.
Any ideas on what it could be now?
Would the clock spring be at fault?
I checked the wires under the seat and the connector and they seem fine. Dry and no bare wires exposed.
If the replacement is a known good airbag, the clock spring would be the next most likely cause. Could also be wiring or an SRS module. You'd have to disconnect the module and airbag and check resistance of the circuit between the two to check the wiring.
1 - 2 of 2 Posts
