Re: (thorne)
Quote, originally posted by thorne » |
You know where I can find it those conditions exist? Dont want to hit that stuff. |
Grapevine pass to the South all the way to Sacramento.
Sometimes they get it up north and it sometimes pushes it's way out to San Francisco. It's too complex to explain, but basically there is no air drainage out of the valley and low level clouds / moisture gets trapped. It's worse on the south end of the valley because most air / weather conditions leak through to the valley via the San Francisco area and the Sacremento River... then compacts against the south valley. It's why Bakersfield see's 120's in the summer.
So, if you took 58... you'll hit that condition all the way down the Tehachapi pass to Bakersfield... and pretty much stay in risk until you reach Sacramento. There would be small breaks in the big cities like Bakersfield and Fresno, but any time you go through an agricultural area... you run the risk.
Normally, I would say you would be safe going into March because temps are in the 80's and 90's, but this year has been brutially cold and there is still snow falling at the 3K mark this late in the season... this south in the valley.
Honestly, If you are going to Chico from Vegas, I would rather take I80.
Hwy99 through central California is 55mph with slow sectons towards Fresno. There is a lot of radar on hwy 99. No one in CA takes hwy99... for obvious reason's. I think you could keep a much higher rate of speed in NV.
If you could get to I-5 here in CA... well you could get the car up to 80-90mph (with a radar detector)... but you'll run the risk of Tule until Sac... so, chances are that you won't carry those speeds.
You'll have to worry about snow on Sunday. It would be idea if you came back over any pass on Monday.
Tule won't be something to worry about after Wednesday of next week... couple days after the storm passes.
'R' Kelly will know about this too... he's originally from Fresno.
