My 2004 V70 T5 is causing me fits.
Runs great, no codes, and starts right up EXCEPT when it's between 15-30 degrees. At that temperature it floods badly.
What it is doing seems to be consistent with a faulty Fuel Pressure Sensor/Regulator. Also, I know that Volvo had a recall on them on some of their models.
I have new injectors, new OEM Volvo spark plugs, new Volvo ECT sensor, and newly cleaned MAF sensor.
My problem is that I cannot find the fuel pressure sensor/regulator. It is NOT on the fuel rail. Where else could it be located?
I thought this generation of V70 had pulse width modulated fuel pumps, so no mechanical regulation.
The fuel pressure regular is in the fuel tank right off the fuel pump outlet. You can read fuel psi with VIDA or off the fuel rail with a fuel pressure gauge.
