1 - 8 of 8 Posts
Hey guys,
I had a short in my headlight switch, tried to fix it, ended up breaking it. Well, anyways, I have a new switch now. My question is, in the back of the switch there is a little side switch labeled A B C. What is it for? TIA.
Re: little switch in headlight switch (mike_c70)
I suspect it's the control to enable/disable the daytime running lights.
Isn't there a section in the manual describing the settings?
Re: little switch in headlight switch (SG)
Thought the daylight running lights were switched on & off by the little black screw in the front...
Re: little switch in headlight switch (topless_tart)
You're quite right, but I was guessing that the screw connects through to the switch in question.
Nope, the little screw in the front activates/de-activates the DRL. This slide switch is in the back of the headlight switch. I guess I have to play with it and figure it out.
Just to update... I found out that the little slide switch in the back is nothing but an indicator for the DRL knob in the front.
what was the result of the initial short? Just seeing if you had the same problem as I did. When I flipped it to night driving lights, I got no automatic tails, only got light with brakes depressed, and there was no light for my instrument panel. If I put pressure on the knob, I got it all back but my fingers killed me for a couple days, haha.
Re: little switch in headlight switch (biggerhurt38)
That is EXACTLY what I had. What I found out was (after breaking the switch of course) was that the contact within the switch was overbent, meaning there wasn't any contact made. Likewise, I had to put pressure on the knob in order for it to make contact. Not a fun thing to do when you have to drive 35-40 miles at night.
1 - 8 of 8 Posts
