1 - 2 of 2 Posts
I have a 98 saffron c70 and found a great deal on a set of 18 inch medusas...was told by the online dealer that they would fit ( 5x 108) only concer might be tire rub.<p>Wrong.<p>A local tire shop mounted the tires (parada spec 2's 225 40 18) and when they tried to bolt them to the car, it turns out the center diameter of the medusa wheel is narrower than the brake hubs on the 98 c70......<p>since the tires are already mounted ( I know should have test fitted the wheel 1st) I suspct the dealer will not take them back....<p>they are OE on the 2006 s40, so would fitting a set of s40 brakes on my C solve this problem......?<p>that's about as tech. as I get, so any advice you all have would be greatly appreciated.......<p>thanks<p>Bleek
Many people have the centers bored out. Don't know about your brake fitment issue.
1 - 2 of 2 Posts
