1 - 20 of 28 Posts
Continuing my build. Ill take used if lightly used and priced accordingly.
Please price competitively w/ shipping to 07002.
All parts are for a 96' 855R.
850 Gaskets - Intake/Water Pump - New Only
IPD Sways - Used/New
850 302mm Big Brake Kit - Used/New
Strut Brace - Used/New
Rear Wiper Fluid Motor - Used/New
850 NA Cams - Used/Preferable New
Thanks in advance. PM's please.
Update: List updated. See my list for this spring!!
^For what's it worth, those are 850 foglights and will work.
I have a sweet set of XPEL protection film perfectly matching these fog lights ;)
I deleted the rear wing on my wagon so I'd be more than happy to pull the rear washer pump for you.
I have an MSD coil, unknown mileage. I got it used, seller said it was pretty new. I ran it for probably four months. I recently totaled my 855, so it's up for grabs.
PM me if you're interested.
Have an IPD short ram with filter and so on... $130 shipped and it is yours. Filter was replaced 7 days before the car was totaled...almost NO miles on filter the rest of it doesn't wear out. comes with a good T5 MAF too
Discussion Starter · #19 ·
going into the fall. some things are dying in the R. need...
parking brake cable
struts/shocks & mounts. sways would be sweet.
steering rack.
accessory idler pulley & tensioner pulley. trying to chase loud humming noise.
cap/rotor new only please. spark plug wires as well.
engine mounts
m56h trans. i have bad input shaft bearing and dying synchros. would consider m56l.
manual shifter assembly. my bushing is shot.
any used performance fuel pumps? im interested.
water pump. timing tensioner. oil pump.
pm with condition.
ill be checking daily until nov.
thankyou in advance.
I have an M56H trans. It was in my car. I don't know the mileage, but it shifted fine. It did have the input shaft bearing noise though. I would change the input shaft bearing if I was going to use it..
$350.00 + shipping.
1 - 20 of 28 Posts
