ok my brake rotors are about 30,000 miles old. ive been reading people with alot more life on them then that. i have a little tiny lip going around mine. can i replace my pads or do i have to replace the rotors are well? they dont feel warped.i dont get any weird feeling while braking in the pedal. my pads are just shot.
thanks
Re: lip around rotors? (veeco3110)
I have that on my factory rotors with about the same miles ... been thinking that some day I'll have that lip turned off (on a disk lathe).
meanwhile they are sitting on the parts shelf with all the other bits and pieces I've taken off the car ....
it's amazing how many extra and un-necessary parts Volvo put on this car
Re: lip around rotors? (petew)
your rotors are extra and unnecessary parts?
From what I've read on the forums, a small lip is okay and actually normal. As long as there are no grooves in the rotor surfaces themselves, you should be fine to replace just the pads.
I have this on the fronts, and will do just pads. The rears might actually be grooved on one side, so I many need to put new ones back there.
ok thank you. every time i look at the brakes and i see that lip i get scared that maybe the brakes are too powerful, or im just braking too hard or something. idk. thank you guys
Re: (veeco3110)
Quote, originally posted by veeco3110 »
Nah...it's just that the stock volvo brake pads are pretty agressive, so they wear the rotor...that's why the stock pads also last a long time...
