1 - 20 of 26 Posts
>> FOR SALE OR TRADE (SET): $1300 OBO plus trades accepted
> Mirzam 18" Volvo Rims - Bored to 65.1mm - Refinished - 45mm Offset
> 235/40/18 Pirelli P6 All-Season tires - 50miles on them - Road Force Balanced on Hunter 9700 w/ adhesive weights
> P2 TPMS off low-mileage, late-model S60
> H&R Extended Wheel Bolts (not installed in photo)
> 5mm Wheel Spacers (not installed in photo)
> Hub rings for 63.4mm offset cars (63.4 --> 65.1)
> Center Caps
>> Why?
> My car is not low enough for these IMO. I am going to put a 17" wheel instead.
> I paid at least $1500 for all of the pieces, and mounted and balanced them myself (I can provide images of the balance and road force values to buyer).
>> What I am looking for (trades):
> P2 R caliper set
> P2 '07-'09 2.5t/t5 front spoiler
> 17" Volvo wheels
> Volvo 960/S90
>> What they look like (actual car/wheels):
Really. I don't understand "not low enough". Explain?
You're a quick drive from me where i work in MoCo (Germantown). I've got a set of thors that need tires soon and was thinking about going to 18's on my AWD to close the gap. Don't think I need the TPMS as I can't use them, or can I?
I'm sitting on B&G springs, and I was hoping that there would be a little tire tuck in the wheel well. Going any lower though, would put axles at too great of a static angle...
Pretty sure the TPMS will work perfectly. Yours is a 05 s60, mine is an 08, so should be the same frequency?
Will pm soon...
i think they look good as is on your car. i doubt 17's will help much with
i really think s60's are big enough never to have to wear 17's.
GLWS/trade.
Discussion Starter · #14 ·
BUMP. I have been on travel and have not had the time to respond properly...but I'm back home now.
CAN REMOVE TIRES IF PEOPLE WANT RIMS ONLY
I've got a set of 17" Mestra wheels. On virtually new Uniroyal TigerPaw (less than 2500 miles)
Discussion Starter · #16 ·
If you were closer, I'd entertain the idea...
BUMP. Going to be pulling tires off soon and exploring other selling avenues.
Discussion Starter · #20 · (Edited)
Yes they will fit a P1 s40/c30/v50. They were 63.4mm center bore, but are now 65.1. I can include hubcentric rings. Without a spacer, they will be +7mm further outwards (45mm wheel on 52.5mm hub). The tire size is correct for P2, but might be slightly larger than P1 18" spec...
1 - 20 of 26 Posts
