Discussion Starter #1
1. Is there any way to keep highs and fogs on together?
2. Any way to make the headlights 55w instead of 35w to match 55w fogs?
1. No, unfortunately the CEM controls that and likely a software issue.
2. This is possible if you bypass the stock ballast and drill a hole into the original stock bulb cap. Not sure if it'll cause a "headlight" error light though.
1. If I remember correctly, others have successfully done this, although you need to find a dealer willing to install the software. Try a search on this site, you should be able to find the part number of the software download.
Yes, use search, this was discussed recently.
