Ok so I have done hid conversion, the manual for my car claims it takes h7 bulbs. I but ended up being h11. So I now want to do the fogs. Does anyone know what bulbs I need. I I don't trust the manual..
<a href=http://s1069.photobucket.com/albums/u465/pardertime/?action=view&current=SC20120812-053850.png target=_blank><img src=http://i1069.photobucket.com/albums/u465/pardertime/SC20120812-053850.png border=0 alt=></a>
My 06 had H1's in the fogs too. I would suspect all the 05 thorugh the 09s would be too.
You will have to modify the bulb holder to allow the HID wires to pass throught the back of if.
Basically what I did was dremeled off the whole back part flush with the two little tabs that you use to twist them in and out of the lens housing.
All the stock electrical conectors /contacts in the bulb holder are removed in this process - you will also have to gut the plastic from inside the holder in order to pass the wires and plugs / connectors from the HIDs through.
I used some silicone to hold the HID bulbs in place.
I let it set up over night and it worked/works like a charm so far.
