1 - 20 of 22 Posts
· Registered
One of the local dealers just got this car and it was at the Mechanic getting looked over.
I stopped by and looked it over. You can tell it was garage kept.
It was bought and serviced 100% in the Richmond area where live.
190k miles, but it is only $2500
Will the volvo dealer give me more details if I call?
04/12/1999 Volvo Vehicle manufactured
Dark olive pearl exterior
Arena leather interior
05/04/1999 Volvo Vehicle shipped to original dealer
in Richmond, VA
07/17/1999 Volvo Vehicle sold by dealer
in Richmond, VA
07/17/1999 32 Virginia
Motor Vehicle Dept.
Chesterfield, VA Vehicle purchase reported
Odometer reading reported
07/26/1999 Virginia
Motor Vehicle Dept.
Richmond, VA Title or registration issued
First owner reported
Registered as
personal vehicle
06/03/2001 Virginia
Motor Vehicle Dept.
Chesterfield, VA Title or registration issued
07/03/2002 Virginia
Motor Vehicle Dept.
06/01/2003 Virginia
Motor Vehicle Dept.
06/09/2003 75,187 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
http://www.mooersvolvo.com
Vehicle serviced
Maintenance inspection completed
Tires rotated
Safety inspection performed
02/02/2004 88,977 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Manufacturer's recommended maintenance performed
Rear brake pads replaced
05/16/2004 Virginia
Motor Vehicle Dept.
06/23/2004 97,855 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
10/05/2004 105,739 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Front brake pads replaced
12/10/2004 110,016 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Battery replaced
03/02/2005 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Tire condition and pressure checked
Headlight switch replaced
06/03/2005 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Four tires mounted and balanced
Brake fluid flushed/changed
Four wheel alignment performed
06/17/2005 Virginia
Motor Vehicle Dept.
08/23/2005 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Oil and filter changed chassis lubricated
03/20/2006 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Front wiper blades/refills replaced
Tires rotated and balanced
06/11/2006 Virginia
Motor Vehicle Dept.
Chesterfield, VA Registration issued or renewed
06/12/2006 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
06/22/2006 Virginia
Motor Vehicle Dept.
10/30/2006 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
06/18/2007 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Fluid levels checked
Maintenance reminder reset
Two tires mounted and balanced
Brakes checked
Battery/charging system checked
Antifreeze/coolant checked
06/18/2007 Virginia
Motor Vehicle Dept.
06/22/2008 Virginia
Motor Vehicle Dept.
06/30/2008 187,991 Mooers Volvo Midlothian
Midlothian, VA
804-594-3500
Vehicle serviced
Tires rotated
02/28/2009 Volvo Cars of North America, LLC No recalls open for repair
· Registered
Re: life after 200k miles (mjbrox)
You should ask for full service records when you stop in as some of the carfax descriptions can be a little off.
· Registered
Re: life after 200k miles (Wayne T5)
well, i guess that is my point
Will they give them to me?
Obviously it looks like the car was well maintained.
But I would like to know about the timming belt, ect
· Registered
Quote, originally posted by mjbrox »
Uh, you're asking the wrong people if the dealer will give you service records- some will and some won't. I have been able to get them on one of the cars that I bought recently.
I don't think you can tell that the car was well maintained from that carfax- there are a lot of entries but pretty large gaps between some of the services too.
· Registered
Wayne, that is a good point,
It just looks like they took it to the same dealer for everything including wiper blades.
I will cal in the morning.
So, the next question is.....am I crazy buying a car with over 200k miles?
· Registered
What model car is it- GLT, Base, T5? Wagon, sedan?
At that mileage, it really depends on the condition (mechanic's opinion) and what deferred items need to be addressed. $2.5 is not a lot to spend for a car but be prepared to spend twice that amount potentially in the first year to bring the car to stage 0 condition. There is a frequent poster on here with twice that in miles (385,000) but I'm sure not without its fair share of repairs. Key is to find a mechanic who specializes in Volvos- they will be a little cheaper than a dealer, and develop a plan for what needs to be done and budget it over time.
· Registered
My Volvo indy has a '98 S70 GLT at his shop that he lets customers use as a loaner car. It has 218K on it, and if you didn't know, you'd swear it only had 18K. Drives smooth and tight, and inside and outside it's almost showroom. Never any accidents or paintwork. He bought it from a customer who bought it off lease at 15K miles. He's serviced it for the last 100K miles. She was in sales and did a LOT of local area driving, not much on the freeway so there aren't even a lot of stone chips on the hood. If I were looking for a car like that, I would buy that one in a heartbeat. It does happen once in a while.
· Registered
Hi Wayne,
I'm that "frequent poster" and my S70 is over 395K miles
at the moment.
Yes, I've had my share of work done on the car - but I distinguish between maintenance (which would get done no matter what car I'd have - fluids, belts and hoses, plugs, tires, brakes, etc.) and repairs (things done because I've kept the car for as many miles as I have).
In terms of repairs - there are two flavors - air intake (the well documented weak spot of my car, with the ETM replaced 4 times, with Volvo paying for 2 of those, and MAF sensor replaced 3 times) - and everything else. In terms of the "everything else" major (over $200) repairs - a/c compressor, radiator, heater core, ABS module, exhaust manifold (the flexible pipe eventually deteriorates), air bag contact reel, rear brake calipers, headlight wiper motors, and an assortment of cosmetic and bulb issues that I've dealt with along the way.
Most of these items were replaced in the 280K to 330K area - the original a/c compressor only lasted 195K miles, so I actually have more mileage on the replacement than the original one lasted.
No rust, and I don't particularly clean the car that often - though I do wash off road salt and bird droppings asap, and it gets waxed twice a year.
I still have the original starter, alternator, coil packs, muffler, power steering, master cylinder, evaporator, and so forth. The interior is original, but for some of the courtesy lights, the gear shift knob (replaced twice), the front window switches that were replaced because I wore the paint off of the door lock switched and they looked ratty, not because they failed electrically, and the driver's door leather panel was replaced after it stretched and tore where I put my elbow.
I never defer anything mechanical, no matter how minor - that's a sure way to get into trouble - perhaps one of the reasons for my car's longevity.
I do have a few outstanding minor cosmetic issues that all require removing the dash pad - a burned out fuel gauge bulb that refuses to go back on no matter how much I tap the instrument cluster area, and the plastic trim by the windshield is cracked. Neither of these particularly bothers me, and removing the dash pad is a few hours of labor, so I figure that I'll eventually have to remove the pad for something more serious and I'll have the other items done at that time.
I totally agree with you that it IS very easy to spend lots of $$ in a hurry bringing a car with an uncertain maintenance history back to stage 0. And I also agree about developing a maintenance / repair plan.
A Volvo specialist is a must, too. Key is also to have the same person look after the car each time. Whether to use a dealer or not is a matter of opinion. If you can find a dealer that charges a fair price for labor, and can give you a parts and/or service discount, for example, for being a VCOA member, then you might get about the same deal on many repairs as you would going to an Indy shop that charges list price for parts with a slightly lower labor rate - especially if a procedure's cost is primarily for parts, with only an hour or two labor.
You can also do some of the routine maintenance yourself. It saves quite a bit of $$ over time. You also get the advantage of going over your car with a careful eye, and can spot things that have to be addressed, before they become a problem.
Hope this helps.
· Registered
Re: life after 200k miles (Bearclaw)
Quote, originally posted by Bearclaw »
Sounds very similar to the one I just bought with 117k on the clock!
· Registered
These are cars that many people buy with the intent of keeping and taking care of for a very long time, and since they can afford the high initial purchase price, they generally have no problem spending for the required maintenance.
My shop guy also had an '83 240 GL as a loaner a few years ago, at the time it had 365K on it but looked like about a 30K-mile car. He sold it to a customer, it has over 400K now and reportedly still runs and looks great.
· Registered
Apples and oranges, as far as I'm concerned.
Not a bad car, I like Hondas, and Edmunds says he is about right on the mark on the price - but I just don't know how much more life a 170K Honda has.
· Registered
Discussion Starter · #19 ·
Re: life after 200k miles (1999_V70)
I drove it last night
It sucked.
ODBII said cyclinder 1 misfire and the bumper had black soot on it.
I have a handfull of wagons I am going to look at this weekend including a Bright red V70
1 - 20 of 22 Posts
