Re: (Quick Brick)
Ok, I now have no alcohol in my system, so as promised, here's some pics from my 04 S80.
First is the rear of the housing. The led strip is the lower rectangle. The green circles indicate where the two wires go from the strip to the back of the light housing.
Next is a close up view of the connector port (I temp unplugged it) that the two wires from the led strip plug into. Note the black housing is stamped "hella".
Next is a pic of the "bulb" side of the above pic. The green circle is the area where the led plug plugs in on the reverse side.
Finally, another pic of the led's in action.
I guess you would need to buy the led strip, cut off the plug on the other end (if needed) and tap into the brake light circuit. Easier said than done. Does the black housing in the "R" have this same brake light plug on the back?
Tim
