Is there a way to repair the led portion of the rear tail lights? The right side is not fully illuminated. But there doesnt seem to be a way to replace the bulbs. It's kind of hard to see in the pics but you should be able to see that the right side (left in the pic) is not lit up where it curves down.
Sent from my SM-G975U1 using Tapatalk
As far as Volvo is concerned, the LEDs are non-serviceable. You need to replace the entire tail lamp.
I had the same issue, and fortunately it happened while I was still under warranty.
Bummer- wow- that is a drag. I have them on my 2011.
Hey take one of those power tools there and fix for good!
QUOTE=rj240;7443127]As far as Volvo is concerned, the LEDs are non-serviceable. You need to replace the entire tail lamp.
I had the same issue, and fortunately it happened while I was still under warranty.[/QUOTE]
