1 - 15 of 15 Posts
I found some early dialogue regarding upgrading interior and exterior bulbs to LED, but haven't seen anything on specific lights forum members have installed. I got some options from amazon, and while the license plate lights are a great shade (6000k), they are way too bright. The interior replacements were too big for the dome light housing. I didn't even mess with the puddle lights. Another member PM'd his choices to me, but I thought I would also see what types others have had success with (particularly anything that isn't overly bright).
Thanks in advance.
I replaced all of my interior lights with these, http://smile.amazon.com/gp/product/B00M8TKQZK. They are definitely very bright, but I like them. The only time the brightness bothers me is late at night when getting out of the car, otherwise I appreciate the brightness and like the look. They did require some type of "restrictor" when installing that was like a $2 part. The guy who works on my car installed them, so I'm not sure exactly what he used.
Appreciate the feedback. Getting a size that fits in the dome light housing is half the battle.
I use these for my front and rear overhead consoles and side mirrors (8 bulbs), no resistor needed, no faint glow when turned off.
http://www.powerbulbs.com/us/product/w5w-led-driving-4000k-warm-white-twin
I use these (2 bulbs) for my rear license plate. Faint glow when car turned off but doesn't bother me. No resistor needed and no CANbus warning in dash.
http://www.powerbulbs.com/us/product/xtreme-vision-festoon-4000k-43mm
There are other temperature options available on that site for W5W and C5W bulbs. I prefer 4000k as it is a slightly warmer yet still a clean white, but not yellow (OEM bulbs) or cold (6000k). Also better matches the Xenon and LED driving lights which are ~4100k. Note that you should use a 43mm C5W bulb to not have a loose fit. These OSRAM and Philips bulbs are more expensive but the much better quality is worth it. I have read many experiences about no-name cheap LED bulbs melting or starting a fire.
I use these (2 bulbs) for my rear license plate. Fair glow when car turned off but doesn't bother me. No resistor needed and no CANbus warning in dash.
There are other temperature options available on that site for W5W and C5W bulbs. I prefer 4000k as it is a slightly warmer yet still a clean white, but not yellow (OEM bulbs) or cold (6000k). Also better matches the Xenon and LED driving lights which are ~4100k. Note That you should use a 43mm C5W bulb to not have a loose fit. These OSRAM and Philips bulbs are more expensive but the much better quality is worth it. I have read many experiences about no-name cheap LED bulbs melting or starting a fire.
Great info! Thanks for sharing.
Has anyone done LED reverse lights and rear fog light?
Do you have a slight faint glow on the interior bulbs when the car is off or is this only with license plate bulbs?
Only the license plate bulbs.
I have never seen that with mine.
What I think you are referring is a small light that shines down on the center console. It shines from a 1/8 inch hole near the map lights. Even with the car off, it will shine for some time after you get in.
Map lights in tactical red: preserves night vision. I leave my LED interior lights in the off position and only turn them on when I need to look for something I have dropped on the floor or loading the car with cargo for travel, because they are so...bright.
Night patrol on the Crest. by Oscar Pair, on Flickr
Your red lights remind me of my red lights in my ambulance HMMV when I served in the Army. No white lights allowed during field training exercises. Looks cool
QUOTE]
At this site, all the info you get is for S60 until 2009. Did you use a different search pattern for the bulbs? or 2009 model bulbs are the same for 2015-18? Thanks
1 - 15 of 15 Posts
