1 - 2 of 2 Posts
I'm meeting up with someone this weekend to inspect and purchase a angle gear if all is well. I know about the input shaft splines, does anyone have a picture of what a good set of splines looks like for my reference? I also plan on listening for bearing noises. One of the questions on my mind is regarding an acceptable amount of play in the gears. Is there any and if so what amount? (yes I have used the search tool prior to making this thread)
Thanks!
Not a lot. Should not have a lot of lash when you rotate the output. Look for weeping at the case seam and see what bent is on the angle gear. If it’s plastic it’s later. Look for RTV on the case.
1 - 2 of 2 Posts
