Re: (mattdoc)
Yep the drains clog, i would remove the pillar and check the hoses to make sure they are clear and then if you can get to them make sure the elbows that dump into the side of the body are clear as well. Some volvo models require actually cutting them back where they pinch together and drain the water as they get packed with junk.
