1 - 8 of 8 Posts
Hi,
Discover after a travel of 5 hour on car, i discover leaking water under side of copilot.
It was very late and had to go to work very early could, only take a few photos and check the coolant, it seemed to be all right apparently.
I think it may be condensation of air conditioning? under the copilot?
Note: it's summer so it doesn't rain in Chile.
drain from air conditioner clogs up. you need to find out where the hose starts and run something through the tube to clear the blockage. I know how to do it on a Porsche 944, but have not done it to a S80.
as everybody said the ac drainage is probably clogged. happened to my dads 06 lexus GS to the point where he needed his carpet replaced.
Thank you,
In the afternoon, check air conditioning system,
any update is the will comment.
Greetings
i have had the same thing once AC OFF ,but i blame the hose comeing from the sunroof drainage in the windshield pillar.probably clogged.
If there's water dripping underneath the car, that means everything is working as it should. When the hose gets clogged the water escapes elsewhere, e.g into the passenger compartment, no?
1 - 8 of 8 Posts
