So i was doing the plugs on my 04 2.5 and noticed that the middle cylinder had about a spoonful of oil in it. Looks like it's coming from the valve cover. Anyone know of a good to tutorial? I just want to make sure there's no unexpected oddities with it.
Sent from my SHIELD Tablet using Tapatalk
to do it properly and not screw up your mating surfaces you need a valve cover removal kit to pop it off. just unbolting it and wedging a screwdriver between the cover and head is guaranteed to F it up.
Clean it up and check again in a few thousand miles to be sure it's the cam cover gasket. It might be something easier, like a dry oil cap gasket or a careless pour during an oil change. Might as well rule out those things conclusively, if you haven't already.
Discussion Starter · #5 · (Edited)
Yeah I cleaned it out and I'm going to check it in a few weeks. This is the first time pulling the coils on it, it has 150k and I've only owned it for a little under a year. Never had a reason to, but now I'm worried that has to be done. I haven't spilled oil, and the top of the engine itself was pretty dry that's why I thought it was a gasket failure.
I bought this cause my friend was getting rid of it and she knew I was into volvos, but my plan is to find a manual awd s40 or s60, so I'm not looking to dump a ton of money into this one. I already did the suspension and a laundry list of small things. If the job is easy enough and it requires it I'll do it, but if it's not something I can do, and its expensive to pay someone else to, I might just sell it as is. But I'd really like to find the car I want first so I'd like to keep it reliable.
