1 - 12 of 12 Posts
I was just on the interstate and saw a cloud behind me, looks like I am leaking oil onto the exhaust at the back of the car near the dem. Is it the haldex ? Ian I safe to drive if I pull fuses??
Help!!!
Do you actually see oil leaking from the dem? Or do you just see smoke and assume this is the case?
If the DEM is leaking I wouldn't advise going far in that condition.
I can see oil dripping/pouring down onto the exhaust
Could I pull a fuse to stop the Haldex pump?
Getting a tow home
So I figured out the issue.... My fault. I installed the IPD cover late last night and one of the bolts upper one snapped. I thought no more of it as I thought it just held the DEM in place not into the unit itself. So there is only 1 bottom bolt holding it in place. F*ck. Will have to remove the DEM and try to drill the bolt out and refill
The bolt broke taking it out :(
Can I disable the dem and still drive it until I can get it repaired?
1 - 12 of 12 Posts
